tashpop
03.24.2008, 07:31 AM
i'm going to go on a limb here and say that won't be enough. just compairing my two setups i have. i've only metered my lsp which made just over 2hp running a hacker c50 L and compairing that to my emaxx running a kb45 on same voltage you're going after. the emaxx's power feels roughly twice as violent. its got to be putting out over 3hp. i notice a significant difference with lower capacity batteries on same voltage. its like i set a 50% training mode on the esc. and that setup is enough to heat up my mgm160, so i'm pretty sure i'm exceeding its amp ratings.
edit:
i miss read. i'm running 1/2 voltage as you'll be running, but still 44amps seems low.
Current Projects
CEN GST Mgm 22418
castle 1717
6s lipo
Losi Aftershock
Infinite 160a esc
Motor Not sure yet
03.24.2008, 09:32 AM
Yeah, I really need to buy some better batteries. Most of my lower kv motors are around 1200kv, so a pair of 4s packs for 8s total would be optimum. That way I can run the motors around 35k rpm. 9s would be just right, but I do not like having different size packs, if only for asthetic reasons.
Thinking a pair of flightpower 4s 25c packs, but what size? Maybe the 3300, 0r 3700? The 3300 should be good for about 3hp, and the 3700 around 3.5hp. Whatcha think?
