Diffs
03.24.2008, 05:14 PM
Which gears are stripped? The ring/pinion, or the internal spider gears?
If it's the spider gears, the problem is most likely a flexing cup. Try an aluminum version.
If it's the ring/pinion gears, I would look at how well they are shimmed. If that's ok, maybe there is a helical cut version available.
Visit BrianG's homepage!
Find all posts by BrianG
