MetalMan
MetalMan's Avatar
03.30.2008, 04:17 PM
why do you still have a reverse module on the thing when ur running BL? is there a OWB?
Anything with an auto 2+ speed tranny will have a OWB. OWBs are put onto the 1st and in this case 2nd gears, so that when the 2nd and 3rd speed clutches engage those higher gears can spin the output shaft at a higher RPM than the lower gears do.
