BlackedOutREVO
04.03.2008, 01:12 AM
do trak power and thunder power batteries use the same balance connector? they both use the v-balance thingy
Yes and no
The TrakPower uses 2 4mm bullet plugs, and one 2mm plug in the center
But I think the V balancer does the normal balance plug, or TP style...
On topic, a 7XL in a LST? Isnt a pretty hot motor for a big car?
04.03.2008, 01:43 AM
edit: "thingy" is a often unheard technical term used to describe the subject at hand, I realize with my high school dropout background my terminology is often over the head of the laman, and for that, I apologize
Thanks para, I had actually mistaken it for a whatchmadinky, which I now understand to be entirely different. I wish that I had studied latin, as these technical terms were originaly formulated by canadians. I have alot of trouble understanding people from canadia, which is somewhere near russia from what I hear.
tom255
tom255's Avatar
04.03.2008, 01:45 AM
Originally Posted by aqwut View Post
HobbyCity Turnigy 6S-100Amp ESC is working great in my Brushless LST on 6S and 9XL... $65 ESC + $14 PiStix.... works great!!
You dont need any PISTIX adapter on this ESC, once you calibrate you ESC with Pistol Grip transmitter it will work on it!
04.03.2008, 01:47 AM
The v balancer has a special harness that plugs into the 2 main 4mm plugs on the trakpower lipo. It also has a a 2mm plug to connect to the balance port. The reg v balancer and the car version are the same save for different colors. Most other flightpower packs have a std balance plug that is the same as thunderpower uses.
http://www3.towerhobbies.com/cgi-bin...&I=LXRWF8&P=ML
Check out the pic, the larger red and black blocks with the male 4mm bullet connectors, also have a female 4mm for the balancer outputs to plug in. The pic shows it already plugged in, but you can buy the adapter seperately, and it will fit a lba balancer with some wiring mods.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
04.03.2008, 03:36 AM
I tried that without the PiStix.. with my 3PK and Spektrum, I had to re-calibrate it every time... And I can't affor a 60MPH RC running out of control... When it's happened to you, you worry..
I had 2x 1940's and 2x 40.160 go into a pond with 48 GP3300 Rainbow packs.... along with my ANCNM Maxx... better safe than sorry..
What Radio system are you using?...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
04.03.2008, 04:41 AM
aqwut- sorry to hijack the thread, I'll give it right back, btw I have 4 new white genesis springs I don't need or want, can you use them?*FREEBIE*
Linc- I'm a funny guy, but you're an all out riot, I believe it's cananada, not canadia, I'll have to ask one of those floppy headed cananadians
aqwut- the thread is yours again
aqwut
aqwut's Avatar
04.03.2008, 10:31 AM
Thanks para... I have about 16 backup shocks for my Genesis.. I do appreciate.. but if you can't find someone to take it, I will... what would the shipping cost be.. to me Canadia
Sorry for the hi-jack as well to whomever started the LST...
I still have 1 LST left... I can't decide to keep it or to sell it....
