jzemaxx
04.12.2008, 07:29 PM
Do you have tubing inside the front shocks under the piston? I will start doing speed runs again soon and I have my truck sitting a bit lower on the front and I know it will create much more down force, but I know it will stay on the ground. I also have a wheelie bar, but I think it won't be needed. I sure hope Mike can do my chassis soon. With the design I have done, I can use 44.4v and 74v with those long packs from Kong Power, Flight Power and Thunder Power.
Yes I have the tubing on all of the pistons. Works good. I have also found the other trick is to strap the front suspension with zip ties to not allow the front suspension to unload, essentially making the front end dead weight.
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
