BlackedOutREVO
04.16.2008, 12:13 AM
Alight, heres a good looking pack
http://www.b-p-p.com/proddetail.php?prod=ab_H800
20C, but the MAH is only 800, so I could do this
6,000 KV motor on 800MAH 3s lipo
Or a 7,300, or 9,000 KV motor with a 2s lipo, and hook them up in series, so its 1600MAH
What sounds like a better deal? I need the run time, but 60 bucks for two 3s packs is insane!
83gt
04.16.2008, 07:08 AM
I use the TP2000 3s in my MLST with a 7000kv motor. Loads of fun. That battery has held up great for 2 years as well. Worth every penny IMO. Is that battery too large for your app ? If so, i'd go with the TP 1320. 800mAh seems kinda small. If you did them up 2p though, you'd have 1600, which would be decent.
J.
BlackedOutREVO
04.16.2008, 10:14 AM
Yes, I need a batt thats around 31mm wide, the hyperion is 34, but thats not bad
Only thing is, is 2p will be for 2s since I highly dont think the bottom deck to the top is over 20mm, so I will probably have to shim the top deck, but thats no problem
rschoi_75
Certified Spaceball
rschoi_75's Avatar
04.16.2008, 12:14 PM
I use this in my 1/18th rides:
http://2dogrc.com/ecommerce/os/catal...nt-p-2177.html
Its a little longer than what you are asking for, but very close. If that is too long, then try this:
http://2dogrc.com/ecommerce/os/catal...nt-p-2175.html
Out of curiosity.... will your track allow 3s? Are you going to be running with other 18R's or trying to race in a 1/10th class with your 18R?
I like the look of the new novak motors, but the kv ranges have me worried. The kv's seem way too high for actual 1/18th sized tracks. I'm currently running a Hacker 4200kv motor in my rc18r, and its plenty for a normal sized 1/18th track. People try to run mamba 8000kv's on the track and they are all over the place. You know a noob has shown up when he busts out the 8000kv motor for a track that only has a 25 foot straight...
rcm xt8
rcm xb8
rcm crt.5
BlackedOutREVO
04.16.2008, 06:52 PM
Those look good, but a bit to wide, im really looking for a short narrow pack, I dont mind buying 2 of those hyperion packs and wiring them in 2P.. But a good choice for sure!
When I race, it will be with 6 cells and a stock 18R motor, this is to have some cheap fun with while my TC is charging. I race 10.5 or MOD sedan, so no on the racing 18R with them lol
I love the range of KV, My back straight is 164 ft!!!! Y E A H ! NEED motor lol my track is darn big, and theres a perfect sweeper at the end of the straight, so motor is def needed, and with the mongoose being a 380 can, it should be a torquey motor, So im hoping I can gear it pretty high, in case I need more speed
rschoi_75
Certified Spaceball
rschoi_75's Avatar
04.16.2008, 07:52 PM
Ok, that makes sense.
How about this one. Its pretty narrow:
http://epyaya.com/product_info.php?c...oducts_id=2531
rcm xt8
rcm xb8
rcm crt.5
BlackedOutREVO
04.16.2008, 09:40 PM
Man, how do you know of all these LOL?
I like that pack! Id run that in 1P, so I think id do 3s, its illegal any way with lipos, so might as well have a efficient system right?
I think I might try those out! Thanks!
kulangflow
Never Fast Enough
kulangflow's Avatar
04.16.2008, 10:22 PM
rschoi is the king of 1/18th scale from what I've read ...
BlackedOutREVO
04.16.2008, 10:24 PM
Possibly
I see him posting on one18th alot, im Money is the Key there BTW
hoober
04.17.2008, 07:54 AM
Does this help?
http://www.progressiverc.com/Research.html
Sammus
Sammus's Avatar
04.17.2008, 08:28 AM
Unless neu make a small high powered motor!
Neu 1100 series are pretty close to 280 size - theyre 29mm diam. I was thinking of getting an 1107/1.5Y for my MLST2, and maybe an 1105 for the mini-t.
Probably wont have a whole lot of room for the gearing with a big motor like that though, and thats assuming the motor holes line up the same.
lutach
lutach's Avatar
04.17.2008, 08:33 AM
With the 54T spur, the smalled I can fit with the Mega ACn16 is a 27T pinion. I didn't try my Neu 1107, but you can try a 29T or 30T pinion.
lutach
lutach's Avatar
04.17.2008, 08:55 AM
What about this one: http://www.rcmodelland.com/index.php...at0=15&lang=en
I have a 3S 2900mAh from them (They don't carry that anymore) and it is pretty good. Now I have a 3S 1600mAh from Kong Power and it is pretty small and can fit an 18R. The only problem is that Kong Power doesn't list them anymore in their site and Air Thunder has them, but only is 2S http://www.airthunder.com/1600mah74v...tterypack.aspx.
lutach
lutach's Avatar
04.17.2008, 10:40 AM
Originally Posted by BlackedOutREVO View Post
The limn look nice, nice mah to!
im looking on the site, found these so far
http://www.hobbycity.com/hobbycity/s...idProduct=6305
http://www.hobbycity.com/hobbycity/s...idProduct=5263
http://www.hobbycity.com/hobbycity/s...idProduct=6472
The 3rd link, I could buy 2 of them, and run them in 2P
http://www.hobbycity.com/hobbycity/s...idProduct=6519
http://www.hobbycity.com/hobbycity/s...idProduct=6426
Thanks guys! And ignore all the links, there more for me to remember, but if you want to help me decide, feel free =)
http://www.hobbycity.com/hobbycity/s...idProduct=6264
skellyo
skellyo's Avatar
04.17.2008, 11:11 AM
The 11xx series of Neu motors has 16mm mounting holes, so they'll line up just right.
Also, FWIW, an 1105 would be way overkill in a Mini-T. It's not too hard to even run a Mamba motor in a Mini-T without temp issues. Heck, I've run a Mamba 6800 in my RC18T without temp issues...gearing is a huge factor with those little motors.
