zeropointbug
Z-Pinch racer
zeropointbug's Avatar
04.20.2008, 05:54 PM
[QUOTE=GriffinRU;164735
Like Zeropointbug, but with less caps :)[/QUOTE]
Yes, exactly... maybe 4 of those caps, at the very most; anymore and you're not benefiting.
brushlessboy16
brushlessboy16's Avatar
04.20.2008, 06:35 PM
Originally Posted by GriffinRU View Post
It is not bad, but to achieve the goal -> there should be no connectors on the path from caps to ESC and wires should be as short as possible.
i know about the connectors, but i dont know if i need it or not, so im going to test it-make it removable for comparison..... If it works out well ill solder it in
