Originally Posted by Cain
I am looking to pick up an E-Revo and combine it with a 4S or 6S brushless setup. What I am wondering is assuming a KV range (4S vs 6S) of 2700KV (4S) to 2000KV (6s), what pinions should be purchased for each of the setups?
Curious if anyone else has found out this info.
you are looking at a lot of RPMs with the battery/motor pkgs if you did this you would need to get a quality motor(not a Feigao) and you will excessive wear on your drivetrain (diffs being the weaklink)
