06.01.2008, 09:03 PM
Another contender enters the ring...
http://www.afterbuy.de/afterbuy/shop...duktid=7826389
This one has a cool little programming box as an optional extra. There are also OPTO version with PC programming, but Im not certain they have brakes, just forwards & reverse (odd...). The site is in german, so I did some translating via Babelfish:
Overdrive Racing Brushless automatic controller Rocket XC 100A Rocket XC 100A - for car and airplane The phantom & Rocket XC Brushless series of Overdrive Racing makes the entrance possible into the Brushless world to an unbeatable price performance ratio.
Description of article Rocket XC 100A:
Brushless automatic controller of the top class from the Rocket XC series with overheating & Low-voltage protection.
Driving option: Only forward/forwardbackwards.
Different starting options of gentle starting on loose underground up to the power start with much Gripp.
Different brake functions of more easily ABS brake to hard Vollbremsung up to the stop. Akkuschutz by low-voltage option, in this option can select you of 0,0 - 49.9 V whether the automatic controller switches or the achievement off reduced.
Adjustable middle gas range of 0-29%.
In 3 stages adjustable timing.
PWM frequency: 13KHz and 8KHz.
Adjustable automatic controller speed (constant speed) only in the switchable flying operation.
Attitude gas relationship for forward and backwards.
Type of model: RC car or flight Programmable by remote control or that particularly for it developed electronic program box with LCD display.
(Program box is not contained in the scope of supply) We recommend very easy and fast programming by program box. (You find the program box in our shop) Also for flight models applicably.
Heres the OPTO version, with a screen shot of the programming interface:
http://www.afterbuy.de/afterbuy/shop...duktid=8106755
lutach
lutach's Avatar
06.01.2008, 10:40 PM
I actually contacted the manufacturer of those and they will make a 6S and a 10S for me to try out and see if it'll work with different types of motors. They should be ready soon as I was told it should take at least a month.
