rootar
rootar's Avatar
04.29.2008, 12:18 AM
Next up my Trinity NOW
http://www.rc-monster.com/forum/show...hlight=chassis
it has a custom chassis i made, stock brushless setup, and 2s maxamps 2100 lipo
weak points : stock chassis is junk and the root of all problems, open diffs are loud, and the spur and pinion are open to dirt
Strong points: high quality stock electronics make it worth it to fix the truck
My setup on 2s has worked great for 3 months now with not a stripped spur gear since i built the new chassis, proving that its flexing and bending was the only problem all along. My setup isnt crazy fast but it will run about 25mph and still has explosize acceleration, and the 2100 provide about 45 mins of running on my track. it handles pretty good once you rebuild the shocks using 25wt rear and 30 wt front. I would recomend this truck to anyone who could build themselves a new chassis out of good aluminum like i did, The chassis is the only problem i have had. Its been a solid truck since the new chassis and alot of fun.
