05.04.2008, 02:32 AM
That doesn't explain why 6s wont be enough. All your saying is that 12s is better than 6s, while you don't prove how much of an advantage there actually is (where is your actual data?) Not everyone is trying to break the land speed record with a monster truck. I would be more concerned about lipo failures than having a setup that runs 20 degrees cooler than what is already acceptable. The more cells there are in a pack, the more vunerable the cells are to undervoltage, since a weak cell has to go way below the safe limit before the mean voltage of the cells in the pack triggers the cutoff.
