tc3_racer_001
tc3_racer_001's Avatar
05.10.2008, 12:25 AM
here are some pics of the underside of the board. there are no pots that i can see, are there different types which look completely different to those commonly seen? thanks
see how closely the 2 rails are divided, do you think that there would be any way without blowing it up to try it?
o yeah i forgot... the 2 smaller blobs near the side, in the middle of photo 1 are the 12v rails... the other HUGE blob is the common rail. hope that makes sense!
yeah i was planning to turn it off use an insulated screw driver (wait till the voltage hasdrained from the caps of course) then adjust it a 1/16 of a turn or something then turn it on and re measure. im not keen on touching it while its connected to 240v!!
btw, where would the pots be??
Name:	pcb power supply resize 2.jpg
ID:	4588   Click image for larger version
Name:	pcb power supply 001.jpg
ID:	4589   Click image for larger version
Name:	pcb power supply 003.jpg
Name:	pcb power supply 005.jpg
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
