Just go Play
Just go Play's Avatar
05.14.2008, 10:06 PM
In your case with the occasional spikes you can limit them (in amplitude not frequency) by setting the max range for that input. So if you know that the highest RPM you would ever see was 35000 set that as the max range so that you will not have off the scale readings messing with your graphs.
This does not fix anything but it will make it less annoying to look at.
Oddly enough I only tend to see those spikes when I power the system up or down.
