Okay for speed it is better to keep the 2-speed tranny (upgrade that gear to HPI's HD version), buy one of those Y-cable's, make lower batt mounts so can use mechanical brake and set it up so only foward/brake on ESC/motor.
And for fun/any other reason lock out 2nd gear, keep keep foward/brake/reverse on the motor and use the easy conversion kit with standard batt mounts. Is there a big difference in top end speed?
So best to use the hd 2speed w/mechanical brake overall then right? I know i want more speed than less of it -lol-
Is reverse hard to throw into the above mix? Just have to add the 'reverse gear module' and a third servo/channel right? Or does it get more complicated than that with placement etc?
Ideally i would like reverse, but it isn't going in if there's more than minor mods that would need to be made, or if it would hinder performance in any way...
I have been running one in my other Savage for over a gallon of fuel with constant use and no issues. Pretty simple to setup and easy to use. Very handy and convenient.
I think I will go with that same setup as you said above as I too am after speed.
Serum...there would be no issues if you ran a 3speed upgraded tranny correct? Just more weight to the rotating mass.
