RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
09.24.2005, 12:50 PM
Do you have another motor to try? In another thread, you said the motor was scorching hot. It is possible that it got so hot that it demagnatized itself(I did this with a 10L once). The motor wouldn't move the truck at all. I didn't try to program it after it happened, though.
Also, check to make sure the programming jumper hasn't come loose. This would cause it to not work(would try to program instead of trying to run). Do you get any beeps when you try to run it? Is the reciever lead from the controller plugged into the receiver in the proper orientation(sounds simple, but I have plugged it in backwards myself)?
