loa
05.31.2008, 02:08 PM
Originally Posted by azjc View Post
the reason I will never buy a new MS operating system within the first year that it is released...
Hehe, I so agree with you on that one that I use Macs exclusively since 1992!
I did gamble with the MMM though so far so good
Hope I'm gonna be able to say that once I plug mine in!
Loa
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
05.31.2008, 02:20 PM
Originally Posted by loa View Post
Any tips to "break" the (first batch) MMM in with minimal risk of failure?
Either it fails or it doesn't. Not sure if there's any way to mitigate the failure.
Originally Posted by MetalMan View Post
Well, you could remove the fan:
http://www.rc-monster.com/forum/show...158#post176158
That's straight from the owner of CC.
That should reduce your chances of having a failure.
Then it might fail from overheating, unless you put a different fan on it. FWIW, my fan failed, the monster is still going strong. I'm not running it tho, due to the fact I don't have another fan to stick on it at the moment.
Why should the early adopters pay for that?
They don't call it "bleeding edge" for nothing.
that goes with being the first buyers of a new item
Exactly.
Castle is doing a great job of taking care of affected customers. Sure, we would have all preferred this to be without kinks, but they happen and are dealt with. Castle is a class act, so I have no worries about the Monster.
MetalMan
MetalMan's Avatar
05.31.2008, 10:02 PM
That is a possibility, but at least for my setup a MM was used previously with no fan, only four 330uF low-ESR caps, and in my 1/8 buggy the MM didn't go above 140 F. The MMM even without fan shouldn't reach anything beyond 110 F, I think.
sleebus.jones
06.01.2008, 10:57 AM
Not what this person reports here:
http://www.rc-monster.com/forum/show...22&postcount=2
I don't think I'd run the monster without a fan, especially down here in Texas. It's been silly hot here lately, no wind, high humidity, etc. Not much temperature differential to cool an ESC. Active cooling is a must I think for larger vehicles. With a fan, you can run without worries, without one you'd probably be checking pretty often.
I vote for the "no worries" option.
MetalMan
MetalMan's Avatar
06.02.2008, 01:15 AM
My bad, I meant in my setup it shouldn't go beyond 110 F.
