VintageMA
VintageMA's Avatar
06.09.2008, 12:31 PM
I've been looking at that CEN for a bit now and based on the measurements of a 6-cell stick pack, I think the following TP eXtreme V2 pack would fit very nicely (with maybe just a little padding to keep it snug):
TP2600-3SXV (25C cont/50C burst)
11.1V 3-Cell
215g
22x41x125
With a ~2500-3000kv motor that would give you a rockin' ride.
“Everyone has a right to be stupid; some people just abuse the privilege.”
06.09.2008, 12:58 PM
Elite cells are good, if you wanted to go lipo, orion/peak have the 3200 and 3600 2s packs that are shaped to fit in those trays. I run a 3200 2s orion in my m03 that has a similar tray. Those lipos use kokam cells, and can push pretty hard. Run that and a 7700 mamba setup and the me16 will be fast....
VintageMA
VintageMA's Avatar
06.09.2008, 01:39 PM
Linc - I had one of the Orion packs and they are good - but don't they require the 4mm bullet connectors that go in from the top? It's a pretty sealed looking battery tray and that may be an issue unless you can get the wires coming right out of the side of the pack.
06.09.2008, 01:55 PM
Yeah, the plugs do go in the top on one end. Is the tray on the me16 completely sealed save for the end?
