Serum
Serum's Avatar
09.27.2005, 07:48 AM
Okay, thanks for that info!
The method you are using (staying above .5 volts each cell) doesn't affect the capacity nor it's lifespan? that .6 volt discharger simple are a few diodes i presume? You could easely make it yourself! Guess i'm in the race for some serious resistors to discharge a 16-20 cell pack with 10A... only downside is that you need to replace the heatshrink more often..
