06.17.2008, 10:51 PM
Originally Posted by Daddydancool View Post
I just received my monster conversion kit for my crt.5 and I already have a couple of 6000mah 2S maxamps, so i was wondering if i can use this motor http://www.finedesignrc.com/nemesisspecs.htm which gives 3072rpm/v
and also what kind of pinion should i use? something big like close to 20t? if this motor is not good, any suggestion for a motor ?
Thanks for your help guys!
I would go with a 7l, and run a 16t pinion, will run cooler than the 8l with the higher gearing (more load), and get it from offshoreelectrics.com
Or see if Mike here at the rcm store can get you a feigao 380c 6l motor. Those are good motors.
