MGM 16018 on 6s li-po
david lamontagn
MGM 16018 on 6s li-po - 06.17.2008, 08:29 PM
I know that this controler can theoricaly handle 6s li-po, but is somebody here run this controller on 6s li-po without any issue.
I run it on 4s for now but i switch to 6s soon, and i'am little scared about that.
I don't use the internal BEC and use mechanical brake.
So i give a big chance to the controller.
Thank you!
David
TexasSP
Something, anything, nothing
TexasSP's Avatar
06.17.2008, 08:43 PM
Mine runs fine on 6s lipo. I do have a koolflight ubec with the internal disabled.
www.cubicle101.com
david lamontagn
06.17.2008, 08:49 PM
Do you install a 20 ohms resistor on the "+" lead to avoid the spark when you connect the batterie???
TexasSP
TexasSP's Avatar
06.17.2008, 09:03 PM
no, it's not real bad, actually more prominent on my mm with 3s.
www.cubicle101.com
andy85
06.20.2008, 07:02 AM
the 16018 handles well on 6s... its stays warm after each 20-30mins bash but never it failed on me...
wallot
wallot's Avatar
06.20.2008, 07:08 AM
no issues at all in muggy with Neu 1512 os 6S
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
