For the Neu motors w/ a RCM motor mount...will I need more than than the rear cover?
For the Neu motors w/ a RCM motor mount...will I need more than than the rear cover? - 06.21.2008, 05:39 PM
Mike sells a front cover for the Neu motors. Is this necessary w/ the RCM motor mount. I know that the rear cover is needed.
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
06.21.2008, 05:47 PM
No, you don't require it, it is to thick for some buggies and isn't enough shaft to be able to put a pinion on. What is it going on?
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
jayjay283
jayjay283's Avatar
06.21.2008, 05:50 PM
I dunno about all RCM mounts but with the RCM losi 8T mount it made the pinion on the factory flat spot mesh perfect with the nue and pinion and spur and covered up some holes large enough for small pebbles to get into. Didnt need it for my emaxx as its all flat against a solid mount.
06.21.2008, 05:56 PM
The Neu will be going into my mbx-5 if that makes a difference. I should probably get it and have it just in case.
