06.25.2008, 06:51 PM
Depends on the esc layout- some have the heatsink directly on & above the FETs (a la MM), where as that hydra has the fins that stick out between each layer of FET boards I think? You'll get higher temps on the electronics, as the fins will drop i temp the further away from the the boards they get due to cooling down...
