azjc
07.01.2008, 02:29 PM
Originally Posted by drkros3 View Post
for the diffs just use mip super diffs, delrin gears, 3 shims on the diff, and one shim on the gear coming off the shaft (i used a washer that goes behind the wheel pin) when u drive it slow its fells really tight but once you get up to speed it opens up and is pefect. i have not strpied a diff yet.
here is my setup
mm esc
8000 kv mamba motor
2 x 2cell 900mah 12c for a total of 1800mah 24c
I have the MIP super diffs but only the stock plastic gears...do you have a link for the delrin gears?
