Go Back   RC-Monster Forums > Support Forums > Unlimited Engineering
Motherload parts
George16
Supermaxx
George16's Avatar
Motherload parts - 07.05.2008, 01:12 PM
Here's a list of parts on the Shock motherload:
OFN 40057 Threaded Ring 4
UE 10122 57.75mm TiN Shafts 4
OFN 40059 Threaded Ring's O-Ring 4
UE 81036 Ø6mm Standoff 4
OFN 40063 Spring Holder (plastic) 4
UE 10125a Spring, White (lightest) 2
OFN 400058 Dust Boots 4
UE 10125b Spring, Red 2
OFN Aluminum Shock Cap's O-Ring 4
UE 10125c Spring, Blue 2
OFN Aluminum Shock Caps 4
UE 10125d Spring, Black (heaviest) 2
OFN Rod End Balls 4
OFN 32033 Bladders 4
M2.5 Nyloc Nut 4
OFN 32235 Piston 4
M2.6x5 Flat Washer 8
OFN 32237 3.5mm O-Rings 8
M3x30 Socket Head Cap Screw 4
OFN 32237 2mm Thick White Spacer 4
M3x45 Socket Head Cap Screw 4
OFN 32237 1mm Thin White Spacer 4
M3 flat washer 8
OFN 32237 7mm Snap-Ring 4
M3 Nyloc Nut 4
OFN 40056 Rod Ends (plastic) 4
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
