sikeston34m
sikeston34m's Avatar
07.09.2008, 12:35 AM
Originally Posted by OldSoldier View Post
OK...I've been trying to come up with a good setup for my new E-Revo also. I'm currently using the following:
Quark 125, Medusa MR-036-060-1600V2-5 1600RPM/V, 15 tooth pinion, stock spur gear, I've tried 4s, 5s, and 6s. I'm still worried about heat, but performance is great at 5s and 6s. But I'm also having cogging issues that I'm having trouble fixing. Motor locks up some times while I'm coasting or braking. I'm still playing with speed controller settings to try to fix.
Hi Soldier,
I've been thinking about giving the Medusa Motors a shot myself. I want the 036-060-2000V2.
Set your ESC to Race Mode, Dynamic Torque, Inrunner Mode (seems to work better even with multipole motors), Normal Braking
In my opinion, you are undergeared.
In Mod 1 gearing with that motor I would go 14/40.
If you're going with the 32 pitch gearing, you probably need a smaller spur and a larger pinion.
You might also try a heat sink with a fan if you're worried about temps.
I've heard those motors are pretty mean.
