OldSoldier
E-ReVVo/SoldierMaxx
OldSoldier's Avatar
07.12.2008, 11:07 PM
I was on the Traxxas forum and some of the folks there are using the Traxxas Velineon brushless system in the E-Revo, but they are using them in pairs! Compared to the Neu, Feigao, and other motors we use on this site along with their high-powered speed controllers, the Velineons are cheap and easy to find. Here is a list of other advantages of this approach:
-Cheap Motors
-Cheap Speed Controllers
-Easy to find at hobby shops
-Great Traxxas support and warranty
-heat is spread over two motors so temps may be lower
-heat is spread over two speed controllers so temps may be lower
-Two ESCs means two heat sinks
-It can be run on 2s or 3s
-Higher kv motor (3500 rpm/v) means less voltage needed (lower temps)
-Velineon is super easy for both installation and programming...no soldering required...everything is in the Velineon combo box!!
Frankly, I can't see the down side. A pair of Velineons (two motors and two speed controllers is about $340. That is much less than a Neu and Quark 125. Mamba Monsters might change that equation since they are not too expensive, but who can find one?
OldSoldier
E-ReVVo/SoldierMaxx
OldSoldier's Avatar
07.12.2008, 11:25 PM
Cheap Motors
OK, I just installed a pair of Traxxas Velineon brushless systems in the E-Revo that I recently saved from the fire. So far I'm VERY impressed. I have only run it at 2s so far (one 2s battery per ESC) and the speed and acceleration seem great for tight tracks. I did notice that I can't pop wheelys anymore I think going to a pair of 3s or reducing the size of the pinion gear would give it the torque to flip itself over from a dead stop. Right now I'm running 20 tooth pionion and stock 68 tooth spur. I'll test a pair of 3s (also saved from the fire) tomorrow.
sikeston34m
sikeston34m's Avatar
07.13.2008, 07:23 AM
"OK, I just installed a pair of Traxxas Velineon brushless systems in the E-Revo that I recently saved from the fire. So far I'm VERY impressed. I have only run it at 2s so far (one 2s battery per ESC) and the speed and acceleration seem great for tight tracks. I did notice that I can't pop wheelys anymore I think going to a pair of 3s or reducing the size of the pinion gear would give it the torque to flip itself over from a dead stop. Right now I'm running 20 tooth pionion and stock 68 tooth spur. I'll test a pair of 3s (also saved from the fire) tomorrow."
From everything I've read, the Twin Velineon setup is impressive. But as with most things, there are pros and cons.
You listed just about every pro known to man. LOL
I don't mean to be negative, but there are a few disadvantages to it also.
1. Extra Weight.
2. More Amp Draw - Lower Voltage setups are going to draw more amps to produce the same amount of wattage output at the motor(s). Which brings us to #3.
3. More heat at the motor(s). I've read where people who run this setup, say it runs hotter than what they think it should.
4. 1/8" motor shafts. Easier to acquire pinion gears, but the shafts are alot weaker than 5mm ones. I've seen more than one broken.
Give it a shot on the 20/68 gearing, but you are probably overgeared. Keep a close eye on temps to make sure you don't fry those motors. I would run it for a minute, bring it in and check. Then run it for another minute or two, bring it in and check.
Let us know hot it works out.
OldSoldier
E-ReVVo/SoldierMaxx
OldSoldier's Avatar
07.13.2008, 06:11 PM
1. Extra Weight.
Update:
I just tried a pair of 3s Lipo batteries in my twin-Velineon E-Revo. I am VERY impressed with the speed! Its about as much as I can handle. I have 8th scale Crime Fighter tires and the balloon into saucers at full speed and spin on asphalt!! The highest temp I saw after a short bashing session with a couple wide-open-throttle runs was 142 on the motor and 137 on the two speed controllers. The Traxxas instructions say the motors should be kept under 200.
I appreciate the Cons...those are some things I had not thought of. I'll continue testing, but I need to go somewhere with a little more room because it is so fast I cant keep it at full speed for more than a second near the house.
azjc
07.13.2008, 08:41 PM
Update:
try going to a local school and run it on a soccer/football field with short grass...it will put a smile on your face.........
