No. Basically, you have to run higher quality cells.
Woah! I just checked the maxamps pack and a 5000mah 4s pack from maxamps is $194! Geez I thought they were meant to be cheap? I've seen the same voltage and capacity polyquest (enerland) packs for significantly less than that.
