07.16.2008, 04:00 PM
Sadly they only do a 3300 or a 2200 50mm
2200 it is then! Or, I might get the 60mm MedUsa. A little overkill, but should run cool.
07.16.2008, 08:34 PM
I didn't play with firmware or settings, but I did boost the voltage to 10 cells (instead of 7), and things work much better. The motor is getting hotter (~200*F!!!!), and this thing is stupid fast, but no more ghosts in the radio. I'm using a UBEC so maybe the voltage from 7 cells was too low and caused receiver issues. All I need now is the proper motor and 3s or 4s lipo.
Steve Krug
Steve Krug's Avatar
07.16.2008, 08:52 PM
Its the batteries fault!!!
Thats the problem i'm having with my MBX5-T electric conversion. Its the amp draw. The NIMH cells can't provide the amount of power to the motor that it needs because they can't handle the amp draw the motor needs to reach full potential. Thats why accel. is slow and braking. I bet the temps of the batteries are about 180 degrees + too.
q8-maxx
E-Maxx Lover
q8-maxx's Avatar
07.16.2008, 09:35 PM
I use 12/90 gearing and temp between 160-180 with 12 cell and the speed 45+ mph. my runtime about 15-18 mins
