Originally Posted by mriccucci
Ok so maybe i changed my mind after looking around. Would it be worth it, to run an airplane ESC with a pistix and use 6s? Do you guys think that the higher voltage will yeild a better run time or should i stick with the s on the MM?
higher voltage will yield longer run times if you pair it up with a lower kv motor, I get 30 min run times with my 6s 5000 FP pack in my converted Revo with a Neu 1515/2.5d
