Pdelcast
Pdelcast's Avatar
07.18.2008, 02:49 PM
Originally Posted by traxxasrevony View Post
i got it in the mail today
but.....
it didnt go so good
opened up the box and took everything out and relized i was missing the castle link stuff, so o well i can get by without it for now.
get everything soddered up plug everything in to calibrate to radio turn the switch,and the fan dosent work with my first one the fan kicked on as soon as i flipped the switch. i dont know if that changed with v2 or not but my fan dosent work at all. also it had the orignal case with the female bullets soddered onto the board and males on one end of the wire which i like more than having the wires soddered onto the board directly.
i dont know if i should run it without the fan working or not but i just bench tested it with the wheels of the ground and i stripped my tranny gears again so i gotta tear it apart anyways
Forgot to mention -- the fan is under processor control on V2 -- so it only runs when required. So don't expect it to run at startup when it is cool.
Patrick
Patrick del Castillo
President, Principle Engineer
