killjoyken
RC-Monkey Poo Flinger
killjoyken's Avatar
07.18.2008, 09:07 PM
I just got my Medusa 36-50-3300 and the instructions (yes I always read them!) say for best efficiency, your esc should be setup with 8-10 degrees advanced. Thoughts?
Matthew_Armeni
Matthew_Armeni's Avatar
07.18.2008, 09:32 PM
It's funny that you mention that because tow weeks ago I was racing with my 60mm 1300 with unknown ESC settings in my 8ight truggy. It ran great and cool all day and I won the sportsman A-main. When I checked the settings later that week my motor timing was set to 10, punch 30%, and everything else to the lowest. I changed the timing back to zero and went to practice at the same track. I was seeing temps on avgerage about 5-15 degrees hotter than before, but driving it felt the same. It was a different day and I can't say if the ambient temps were the same but it made me think, is a little timing ok? It definitely did not hurt my runtime. I was running a Hyperion 6s 4250 18c pack, it was a 12min main, no warm up laps, just drove over the loop to register and then sat by the grid. After the race I charged my pack and put 2390mah back in. I think I'll put it back to 10 and see what it does tomorrow, another race, same track.
  Send a message via AIM to Matthew_Armeni
bdebde
That's All Folks!
bdebde's Avatar
07.18.2008, 10:32 PM
My Lehners seem to run hotter when timing is 0 or 5 deg, cooler when 10 degree. I guess I will have to try them at 15 deg, that is timing used by Lehner for all their specs.
sikeston34m
sikeston34m's Avatar
07.18.2008, 11:39 PM
For timing, it's best to go with the manufacturer's recommendations.
Multi-pole motors like more timing than do inrunner 2 pole type motors.
There's really no comparison between the two in the timing realm.
What applies to one, doesn't necessarily apply to the other. It's not Apples to Apples.
