07.26.2008, 11:09 PM
On the radio: Set the throttle trim to 0. Set the EPA to as high as it can go for both forward and reverse.
On the ESC: Set the the "noise cancel" setting to "off" and the "neutral range" setting to "normal 1".
Recalibrate the radio and ESC together.
I've used two Quark systems both with Spektrum systems and they worked perfectly. Once you get your system running right, you might want to set the "neutral range" to "narrow" for the best slow speed control.
Trick440
07.26.2008, 11:24 PM
I did what Brian suggested and its still bad.
It I keep rapidily turning the steering just an 1/8" back and forth I can get this thing to go full throttle, stop, go, slam into reverse, etc. Its crazy.
I gotta go to bed I'm super tired, but I need to get this thing running for tomarrow so I will be throwing in the old TX controller and reciever. I'll let you know how that works out., thx
jhautz
jhautz's Avatar
07.27.2008, 12:10 AM
If you are running an external BEC try disconnecting that and running a receiver pack to eliminate the external BEC as the problem. The other thing that could be possible I suppose is the steering servo going bad and creating some sort of interference int he signal of the whole system, but I think the BEC is the more likely culprit.
to make it...
or break it...
Silent...But Deadly
07.27.2008, 12:47 AM
I had a similar issue with a bad steering servo. As I pulled the throttle the servo would twitch a lot and stay off center. It did not casue any issues with the control of the esc though.
Try a rec pack, and make sure it is fully charged, a pack with low voltage will cause all kinds of problems...
hailmick
07.27.2008, 02:41 AM
try switching your steer servo out like the boys above have said
my buggy has a twitching steering servo but its a nitro its even worse when steering
Trick440
07.27.2008, 01:21 PM
I think we maybe on track. I tried the stock reciever and same problem. I unhooked the steering servo and problem went away. But there is no steering servo hooked up. Im going to hook the stock steering servo up and see what happens.
