07.27.2008, 03:57 PM
Brian that looks really good.
07.27.2008, 04:38 PM
you gonna run a gyro??
07.30.2008, 06:49 PM
I don't know, probably not. But then again, once I do a few high speed runs just to see how fast it can really go, I'll probably drop the gearing to something more reasonable and play. If I do that, I might use a gyro to help compensate for my less-than-stellar driving skills.
I stopped by the LHS to show off my project. Let's just say I got a lot of positive feedback! No one recognized the GTP because of all the custom stuff, and once they knew, they couldn't believe it was all done with basic tools (Jigsaw, Dremel, files, hammer, vice). A couple even took pics with their camera phones to show the only other electric-head there; Dustin (glassdoctor), but I told them he's probably already seen this thread.
While there, I picked up a set of Revo springs for the front since the stock springs were not close to stiff enough to keep the front from dragging at high speed (lots of downforce) and weight. We started with the purple set (highest rate) and it was a REAL PITA to get on there! It took two of us, and neither are small guys! Well, all that work and purple was too stiff. I went down to the golds and it was perfect - still a PITA to get on there, but not near as bad. To match the front, I had to dial in max preload in the rears. Seemed just right. I'd like to get a stiffer set in the back so I don't need quite so much preload, but don't know what will work.
TEAM FUSION
07.31.2008, 02:55 AM
LOL!!! I got to the track and Shaggy (like 6'-6" and looks like the cartoon dude) showed me the pics he took... "you gotta see this"
I was like... "oh yeah... I know all about that already..."
But I would have liked to see it in person, so if you are by the track next Wed bring it along. :)
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
07.31.2008, 09:43 AM
I know who you're talking about, but I didn't see him there? It was a few other guys. Justin (I think that's his name - the guy behind the counter) and a couple other guys I didn't recognize. It must have been when I was looking for other parts.
07.31.2008, 03:53 PM
That looks amazing Brian, great job on it. You make me want to get one.
08.02.2008, 11:39 PM
Thanks, E-Traxxer.
Anyone know where to get a suspension spring coupler? I tried searching, but don't think I'm using the right terminology. The rear-end of this car is too soft even after dialing in max preload - especially after installing Revo springs in the front. But I don't know of a stiff-enough spring I could use there. So, I thought I'd use the stock rear spring along with the stock front spring stacked together, but I need something that will keep them inline. I hope I explained that well enough.
08.02.2008, 11:43 PM
Thanks, E-Traxxer.
How much does the car weigh Brian? Mine is about 9lbs ready to run and I was able to get the rear arms slightly above level with stock springs. I played around with the mounting positions.
08.02.2008, 11:51 PM
Thanks, E-Traxxer.
I would think that a piece or two of heat shrink, applied when the springs are assembled end to end with the shock body in the center would work. Maybe add a small amount of glue to help it hold together. Or find a piece of thin wall plastic tube that fits perfectly to the outside of the spring, but that sounds hard to find. Heatshrink sounds like the thing I would use...
I llike the idea, and was going to suggest to stack 2 springs together (revo or jato) to get the extra length. Came up with that a few days ago, while staring at my gtp.
08.03.2008, 12:27 AM
B4maz: Not sure how much it weighs, but it's a bit on the porky side for a racer - at a guess, around 9lbs without batts. There's a lot of material to make the chassis very stiff and to keep airflow under the car.
linc: Yeah, I tossed around a few ideas, but I could have sworn I saw what I was talking about somewhere. I think I've seen an emaxx or two that used dual springs and used this type of coupler. Don't know if something like this is made for 8th scale though. I guess I'll just look around for ideas...
08.03.2008, 12:30 AM
The HPI Savage Big Bore shocks (HPI upgrade) have these spring coupler things. Honestly I can't think of a name for them either, but maybe it would help to know that they are used to create a progressive spring setup.
08.03.2008, 12:46 AM
Hmm, searching tower turns up nothing. Either use dual springs, or find a regular set stiff enough. Maybe a set of the stiffest spring option with the preload maxed may be good enough. Hmm.
08.03.2008, 02:49 AM
Nice Project....So when are you gonna be running this?
OT: BTW, where did you get that 911 Body? I can seem to find any online shop that have it on stock...
08.03.2008, 11:23 AM
Brian,
GS Racing used them for a "dual rate" spring kit. I have them and aren't using them, so PM me and I'll send them to you.
08.03.2008, 01:07 PM
Truckbasher: It came with the Ultra GTP kit. Already painted, all I had to do was cut it out and attach the stickers. I'd imagine you can order the body seperately.
killajb: Thanks! I'll be sending you a PM...
