07.30.2008, 08:34 PM
Thanks! But, if you go that route, make sure the UBEC input/output grounds are electrically common, and the ESC power ground is electrically the same point as the throttle cable ground.
If and when I do this mod I WILL look you up again...thanks Brian for the advice!
