08.02.2008, 09:06 PM
Boat braking is usually just enough to stop the prop moving, and then it switches to reverse. As long as the prop stops for a second, it is ok for it to go into reverse, as water does not "grip" the prop like the ground does to the tires. Sounds like you will have to go forward only with mech brakes...
I have setup a hydra with the castle link and do not remember a different brake setting. I suppose that you do not have a castle link?
