dpb318
08.06.2008, 11:28 AM
to get the back cap off just stick a screwdriver in the opening for the wires and pry it off...the jb weld should break free if you rotate the screwdriver to apply even pressure to the whole back...itl pop off eventually it may just need some encouragement...if all else fails get a blowtorch and heat up the edge of the can where it is glued and that should help
