rhylsadar
rhylsadar's Avatar
08.12.2008, 04:35 AM
hi
101001
you may choose the second one on 1 too. boat modus has a very smooth brake that may put less stress on your drivetrain.
bye
rhylsadar
ps: put a nice fan on the heat sink and solder some short leads to the 3.5mm plugs. so you do not have to remove them anytime you take off the motor. you may solder 4mm on the other end to connect to the motor. also two additional capacitors are not a bad idea.
______________________
Exercitatio artem paravit
rhylsadar at youtube
