rootar
rootar's Avatar
08.14.2008, 07:49 AM
shaun its a whole different world driving a 2wd, alot have bought slashes at the track (just to run and play in another class) and 70% of them are coming from buggies or truggies and they flat out can not drive a Stock slash much less a brushless one, you really just have to be EASY on your throttle control, but if you can drive a 2wd good it reallys helps when your driving everything else.
also unlock the rear diff, locking the rear actually makes it harder to drive, pack the hell out of that gear diff with AE diff grease and thats all you need. also switching to different tires makes a HUGE differance, but with better tires itll also tend to traction roll more so keep that sway bar on it youll need it.
