IMO, a 6s 6Ah pack is too much for one side if you are running a single pack. I run the 1515 1700kV with 5s and wouldn't think of going up in voltage. It requires you to run low capacity packs to keep the weight within reason. Your set up should be fine in the heat if you have a well ventilated body and 5s with proper gearing.
