crazysavage
08.17.2008, 04:02 PM
Originally Posted by maneba View Post
3S is a value too low for a vehicle like e-revo. You should use at least 4S
Is the 4s rule more for power or for effeciency? I just ran my e-revo with 7.4 lipo, MM and a 7700 CC motor and I had wheel stands with a 12 tooth pinion and a confirmed 41 mph. This was just a test and the speed control reached 175F and the motor reached 130F and the battery came off at 109F, indicating the truck was over geared. I know the 7700 wont last in the revo but the Neu motor will solve that issue. Is the motor I listed OK for the revo? Based on that test with the 7700, 4s will be just too much power for racing but if you need 4s for effeciency, I will just have to tune every thing down and gear it low. Thanks for the help.
maneba
08.24.2008, 10:45 AM
4S-5S-6S and motor with low KV (from 2200 to 1700) are for power and efficiency.
7700 Is for 1/10 1/18 vehicles. With more volts you'll run cooler, longer, and with much power.
crazysavage
08.24.2008, 12:34 PM
Thanks for the info...I ran the heck out of the revo yesterday with the 1512 2df and even though I was under geared slightly, I was just amazed. It's on 4s right now and I am getting great temps all around and fantastic run times on 2 5000mah 7.4 lipos. This track had 6 or 7 guys running brushless buggies and truggies and I got even more valuable info. All I need now is a couple 62 and 65 tooth spurs for fine tuning and I can pack up the entire package and send it off to my son in england. Then I can get to building something for my self. Anybody in the market for some really high quality Nitro engines.
