azjc
08.24.2008, 08:02 AM
Originally Posted by e-mikey View Post
How many amps should I be charging my 2s2p 6400 mah batterys at, and is there a formula for figuring this out?
I also see people mention charging at 1c. Is this a setting on the charger itself?
1c is the packs capacity, 2c would be double the capacity...so in your case you would want to charge @ 6400ma, you would need to program the charger yourself
