azjc
08.24.2008, 09:27 PM
IMO there is a lot of jarring going on with off road trucks especially with speeds approaching 50 mph and all it takes is a loose connection to cause a short.....both the MMM and MGM controllers are good...I dont think buying one brand over another will keep that from happenning in the future. I do like to make mounts that have foam and/or female velcro to help absorb the shock
Countryhick
08.25.2008, 06:54 PM
This is possible with what some of you off-road guys get up to . But I run mine in THIS
and I only run it on a purpose built track. The strange thing in common about these MGM failures is the fact that they run fine one day then let the smoke out the next . In my instance I had driven the car the day before (temps all good) then the next day I had the car on the bench about to have a drive. Plug in the battery (deans plugs) and POOOOF!!! the dreaded white smoke .
Tick tick tick tick tick tick tick.........
david lamontagn
08.25.2008, 07:03 PM
On mine, there was not only smoke, but alot of fire
The negative bare were the black batterie lead connect on have literaly disconect from the 4 PCB and short with one of the capacitor.
The only thing i'am little scared, is my li-po pack. Don't know if the pack is fine after this happen.
I've recharge them, both pack seem to have all the cells at the same voltage, but i've a pack with an internal resistance of 36mohms and other one with 68mohms.
This is 2 identical pack (TP V2 extreme 5000mAh, 3s) and have always been use in same time.......
