VintageMA
VintageMA's Avatar
08.26.2008, 04:33 PM
Originally Posted by Finnster View Post
The only thing I'm not so hot on on the .5 (besides the shocks) are the F upper arms. Mine haven't broke, but the small turnbuckle is a bit bent. Been fine for a while now, but if there is a flaw that would be it. Oh yeah, the servo saver... prone to breakage if its mounted in the outer ackerman, inner ackermann and its fine.
I've gone through at least 4 upper front turnbuckles. I even tried a Ti pair and they snapped just as easily. (I can never understand why people say Ti is stronger because every piece I've ever upgraded to Ti has snapped or bent more easily that the Al or steel one it replaced and I just end up going back to the stock metal anyway)
I killed the servo saver on the crt.5 but then just replaced it with the upgraded aluminum one from Nitrohouse (the Al upgrade parts are pricey but the quality is really impressive).
Has anyone tried the extended A-arms Mike just put up on the site? I am tempted, but no sure how much of a difference .6" is going to make. And if the upper A-arm is now made out of Al and I snap a turnbuckle in the threads I am going to have to dremel a very expensive piece of metal to get it out rather than a cheap piece of plastic.
“Everyone has a right to be stupid; some people just abuse the privilege.”
