09.03.2008, 10:26 PM
Info about the motor and esc and battery would be helpful...
It has small tires, and is not as heavy as a revo. I would consider the load to be similar to and 8th buggy, and some run that with a 3s setup. If you are going for track speeds of 35mph or less and are using a high qual motor and battery it should be fine. A feigao/maxamps setup will not be fine, where a neu/enerland will work. $s will yeild better temps though.
I plan to run mine with a c50 l can and a 5s 3700 pack... Or maybe 4s...
