09.04.2008, 10:14 PM
Did you disconnect from MMM - Those huge wires act as great heatsinks
That's All Folks!
09.04.2008, 10:15 PM
I think they use lead free solder, seems to take a bit more heat. I managed to get it by feeding a little more solder into the wire.
09.04.2008, 10:40 PM
Yes, they were disconnected - I'll just snip off the ends and start from scratch. Does this mean that I should re-do the bullets (is there a compatibility issue with my solder and theirs that would cause a continuity issue?). BTW, speaking of soldering the bullets - I read about how people filled the cup with solder, then stuck the wire in. My bullets have 2 holes in them, so filling them was not really an option. However, I drilled my hole in the workbench a little deeper, so that the holes were covered and filled it that way.
09.04.2008, 10:42 PM
No need to touch the bullets...
09.04.2008, 11:25 PM
Or if you dont want to snip the ends try melting some other solder onto it, in my experience diluting it a little helps a lot.
09.04.2008, 11:38 PM
i tried and failed with their solder. just ended up cutting my ends off and redoing it, as stated above
09.05.2008, 01:54 AM
In my current setup the bullet configuration causes the wires to push up on my body slightly. I think I'm going to re-solder the wires to the sides of the bullets at an angle instead of inside of them.
I'm still on a v2.0 with about 15 minutes on it.. I'm supposed to be racing tomorrow but I don't know if that's going to happen :(
-Jeff
BL 8ight, BL FT B44, BL FT TC4, BL FT T4
09.06.2008, 01:40 AM
the thicker the gauge of wire the more heat, flux and skill you need. A good 100+ watt soldering iron is a good investment.
09.06.2008, 01:40 PM
I got mine done - clipped off the ends, and redid them with my solder. Took the MMM/10L up and down the street a couple times, and it operates as described.....just need to get some fresh packs in it to really test. I am REALLY unhappy with the lack of screw down holes. I hate the zip tie messy look.
E8ight T
09.06.2008, 02:10 PM
Just got my v2 MMM yesterday!!!
Thanks Mike....
Should i direct solder mine, or do i need to get 6.5mm bullets? my MMM didnt come with any male bullets, the MMM HAS female 6.5mm bullets installed on the MMM, but no males???
It came with 3 motor wires 6" long, an 2 battery wires 6" long, stickers, a cd, a usb wire and chip to plug the MMM to the usb, but there isnt any bullet plugs...
My hobby shop has 4mm bullets , but no 6.5mm bullets, will the 4mm bullets work to conect the motor to the esc wires?
I read some post that said only 6.5mm or dirct solder is to be used/done on the MMM...
Gary Antonietti #9
Losi 8ight T - Monster Mamba - Neu 1515 1y - MaxxAmps 3s/4s/5s 8000mah - Futaba 2.4GHz Tx/Rx 6EX - Futaba S9351 servo - 15/46t gearing
FTT3 -Mamba Max - 2s 8000mah
09.06.2008, 05:31 PM
Thanks Mike....
The wire's don't have male bullets on them on one end? Mine did, and the only thing I had to solder was my choice of ends to connect the motor (I used 6mm bullets for that). I did attempt to use 4mm, but the wire wouldn't fit into the socket on the bullet.
09.06.2008, 05:50 PM
As did all of mine..
09.06.2008, 07:43 PM
use double sided tape :P
09.06.2008, 08:12 PM
Personally I prefer cable ties combined with double sided tape over any screw mounts.
09.06.2008, 09:41 PM
ah its good to see patrick and co are RoHS compliant. green manufacturing, the way of the future. yes that lead free solder is a royal pain to work with without the right tools/ solder iron. i just gave mine to one of the shop guys and hey presto...all soldered. TBH if i was to do it, i would have used the leaded solder, i am very impatient.
123.
