Originally Posted by lincpimp
The MM should be ok with the 1.5d. Just run an external ubec and a fan on the esc. Maybe add another capacitor. It will pull about the same amps as the 7xl. Plus the neu will be more effecient, and use lower gearing than the 7xl for the same speed, the neu has a higher kv, 2700 vs 2300 on the 7xl. It may even pull less than the 7xl, maybe?!!?
that sounds good dont really want to spend more on another esc
what type of cap would i need to use on the m/max i dont no nothing about these but i no you put them on the main power wires
i wouldnt no where i could find one either im over in the uk
i do use a ubec on the max all ready got this from mike
do the small 25mm fans really help keep it cooler or shoul i go bigger like a 40 mm fan
