I'm building a E-revo for strictly on road speed runs. I'm going to be using Zippzy 25C batteries along with a MMM V2. My question is what Nue motor would you guys suggest for this setup. Again this is only going to be used for speed (no offroad) I have a bashing truck already for that.
6S I would go with the 2D.
4S I would go with the 1.5D.
You could easily gear into the 50-60mph range with ~40-45k rpm. You said you wanted speed runs so I assume you want faster than a racer. I would also get the 17mm wheel adapters and run with the HPI Phatline tires - great on-road tires for a truck because they are so low profile.
If you are going to running Zippys I would go for 6S/5000mAh to keep amps and temps down.
“Everyone has a right to be stupid; some people just abuse the privilege.”
Thanks guys... Yes I will be running 6S and already have the 17mm Phaltlines. I do plan on messing with the gearing but I just want to make sure I get the most efficient baseline motor and go from there.
In this case bigger is not better as at these power levels your batteries are the limiting factor. I would go with the 1515 1Y. This is the motor that castle creations recommends for the MMM and 6s and they claim 60 mph. The 1Y has just a bit more rpm than the 2D, and Y winds are slightly more efficient than D winds.
I have the 1y and 2d used both in an emaxx (same drivetrain as erevo). If you're going for max speed on 6s, 1Y for sure. Youll need mikes 1/8th revo diffs very soon though. The 2d on 5s is a nice basher, then again so is the 1y lol.
