questions before a LSP brushless project
speedsecret
questions before a LSP brushless project - 09.09.2008, 06:52 PM
Hi all
I'm new here and I will like to get your help to build my first brushless truggy .
i have allot of experience with electric RC but i never done any nitro to brushless conversion yet.
i want to convert a new HB LSP with a Novak HV maxx system
i know that allot of people don't really like this system but i think it will satisfy my needs.
i want to build this truggy for racing tracks so i don't care about the top speed or thing like that .
i think of getting the hv maxx with 5.5 motor and use it with a 4s lipo
now the questions
do you think the 5.5 motor is too fast for driving on track?
what pinion size should i use?
do i have to change more parts accept the brushless motor mount that i will buy from the site store?
how much running time i will get from 5000mah 4s lipo?
do i need a ubec?
thanks all
i really want to start build all ready
09.09.2008, 07:39 PM
Welcome
You should just need the RCM mount - I would get the 5mm rotor upgrade - Check out the novak area as they were offering to give a few away.
The battery trays are worth looking at - The speed calc can be used below to work out your pinion - Gear for about 37mph for the track
http://www.scriptasylum.com/rc_speed/index.html
Semi Pro
Semi Pro's Avatar
09.10.2008, 02:51 AM
Originally Posted by speedsecret View Post
Hi all
now the questions
do i need a ubec?
thanks all
ok i have a brushless LSP with the novak kit so i will try to help
the 5.5 is to high a kv even the 6.5 is too
i have a 6.5 geared 11/48 at 11.1v the top speed is 36mph
i race so this is alittle higher than i want but it stays very cool
power is supriseing good
the only other parts you will need to get started is a plastic center diff gear and a pinion
im useing a castle creations bec since in only useing one battery lead and a 3 cell novak smart stop for the lipos
im getting about 20-30 min of run time on a 5000mah lipo on tight tracks
here is mine http://www.rc-monster.com/forum/showthread.php?t=14909
speedsecret
09.10.2008, 10:48 AM
thank you for your replay guys .
so maybe i should go on the 7.5 motor?
and if i will use a 4s lipo it will cause the motor to get warmer then with 3s?
also a friend of mine advice me to go on the mamba monster esc a neo motor
so what you think?
Semi Pro
Semi Pro's Avatar
09.10.2008, 09:21 PM
if you are going novak then i would go with the 7.5
i would wait for castle to figure out how to fix their problems with the mmm
neo motor? i havent used a neo yet so i dont know. if you can afford a Nue motor then its worth every penny, a 1515 1.5D would be perfect
