crazysavage
09.12.2008, 03:01 PM
It should work fine. I will be using the tekno battery tray, but have a different motor mount, as I do not care for the clutch. That 1.5d will be crazy in the slayer. I am going to run buggy wheels and badlands on my slayer. I am not all that impressed with the stock tires on the slash which are very similar to the tires on the slayer...
Sounds like a crazy set up. I would advise the clutch set up with aggressive tires and the mech brakes to allow some tuning and some slippage in each respect. I know one thing, no matter which way you go, I wouldnt run it full throttle over your front lawn with those tires unless you want a bunch of little parallel drainage ditches criss crossing all over the place.
