bruce750i
bruce750i's Avatar
09.12.2008, 04:47 PM
60mm 2k medusa worked good in mine on 4s and shifting 20/36. So much air going thu the body it stayed around 120F motor & ESC. How many rpm's does the TRX3.3 make? What kv on 4s would be close to stock nitro speed?
phatmonk
RC carbon junkie
phatmonk's Avatar
09.12.2008, 07:13 PM
Yes the Medusa is a great option.I have wanted to check these out.
09.12.2008, 07:39 PM
The slayer should be a bit lighter than a revo, and has much smaller tires. I would think that a Medusa 60mm would be fine. My hacker c50 13l is about that size, and those motors work great is 1/8 buggies, which are comparable to a slayer.
Got some parts!
Got some parts! - 09.12.2008, 07:40 PM
Look what the mailman dropped off today:
phatmonk
RC carbon junkie
phatmonk's Avatar
09.13.2008, 05:46 PM
So I have a Tekno Slayer conversion a Slayer a MMM v2 a Motor now do I need a servo Y harness or a center diff conversion ?but the specs say on the Slayer that it has a forward only trans.Long story short is I want to go with a pinion and no clutch and use the MMM brakes.But on the otherhand the instructions for the conversion says I need a y servo harness when using the clutch setup.I have converted 2 1/8 buggies and a Losi 8T truggy those I have a good working knowledge of what to do but with the traxxas Slayer and 2 speed I need some guidance.Do I need RCM Motor mount?
chip cross
09.13.2008, 11:36 PM
Are you done yet, my Slayer will be on the 16th and the Tekno conversion will be here on Monday. LMK when you ready for it.
09.14.2008, 01:59 AM
I finshed the roller today, as I had to build mine from parts it took a few hours. Looks cool, that is for sure. I have a set of white ofna 5 spoke buggy wheels and some badlands on it, they look good with the black, red and white body off my slash.
Should have the electronics in it tomorrow, as long as I have time...
Final setup is a hacker c50 13l, quark 125b, ccbec, and a poly rc 3700 5s 25c lipo. Going to gear it for 45mph which should be 20/36 gearing. I am using a revo tranny locked in 2nd with the wide ratio 2nd gear. I understand the slayer has specific internal ratios to suit the smaller tires, I will just use a big pinion to compensate.
09.14.2008, 01:04 PM
If you plan to use motor brakes you will have to lock the 2 speed in 2nd gear. There is a sticky in the brushless section by BrianG that will show you how to do it.
The FOC kit that the slay comes with is also needed, which is good since you already have it.
phatmonk
RC carbon junkie
phatmonk's Avatar
09.21.2008, 09:17 PM
Heres some pics of the Slayer so far.I was gonna go with the Tekno clutch but changeed plans.It does have a tendency to want to flip but if you are carefull its controlable.It drives like a grape ape.I went with a Neu 1512/1.5d/f and 3s lipo 6000.Lincpimp can I go with a 18t pinion?It now has a 14T with stock forward only trans.I also ofcourse went with the mech.brakes.I did hammer on it a few times an the MMMv2 worked perfect.I was gonna use a mx3 fm radio but it glitched like crazy with the steering servo so for now it has the stock radio and no problems.
09.22.2008, 07:55 PM
I managed to get a few mins on the slayer today. I have to say that it will tracktion roll on concrete but handles reasonably well in the dirt/grass. It has plenty of power and will wheely easily. I do like the truck, very fun! I have a feeling that I would not be as fond of it with stock tires, if they are anything like the slash tires, they suck...
phatmonk
RC carbon junkie
phatmonk's Avatar
09.28.2008, 04:27 PM
I couldnt find where to post this question so I hope its ok to ask here.I have 2 5mm bore pinions 1 is a mod1 and the other is a 32 pitch how do I tell the differance.They look identical
